Compression test #'s
Old Mar 13, 2007 | 07:46 PM
N2oExpresS2k's Avatar
Default Compression test #'s
I tested my car the other day with a $hitty tester and got 205-210 throughout. What's the highest you've seen from a stock S ?
Old Mar 14, 2007 | 02:40 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Depends on conditions.
I've had 230+.
Old Mar 14, 2007 | 09:42 AM
CIVICTOS2000's Avatar
around 240 about 6 months ago...
D.
Old Mar 14, 2007 | 09:51 AM
silencertk's Avatar
I recall having around 225-230, engine warm.
Old Mar 14, 2007 | 02:06 PM
I'm going to try that again with another tester and the engine warmer. When I did the last test I warmed it up untill the thrid bar lit up and then I shut it off about 30 seconds later. Took a little before I had the sparkplugs out. By the way, do these sparkplugs look alirght or does it look like i;ve been running lean ?
Old Mar 14, 2007 | 05:57 PM
mxt_77's Avatar
I get about 240-250psi w/ a Craftsman tester.
s2kbtos
Nov 8, 2015 11:06 PM
AZ-S2000
Mar 19, 2012 08:40 AM
EK9MAX
Jul 6, 2009 11:17 PM
