Comptech with AC and a FRP insted of Comptech FMU
I am runnig a Comptech with AC and Costum Intercooler (tech2motorsports), I also have a toda header and stock exhaust and a Walbro 255 lph@90.
Currently runnig lean, Since get the car tunned with electronics here in Spain is very complicated. I have to take the "old way"
I will change the FMU for a SX Regulator (30-90 psi).
Will like to know which the the max pressure that the stock injectors can handle
I will used a wideband to "tune" the FRP
thx
thx
Juan, Removing the FMU is NOT a good idea without some other form of additional fuel control.
Do not drive your car in boost without a FMU and just a FPR. It will be much leaner than it already is.
The stock injectors can take 125psi of pressure, that's what the stock Vortech FMU makes. 10:1 FMU, 10psi increase in fuel pressure for every 1psi of boost. 50-55psi of fuel pressure stock, +75psi from the FMU, 125-130 psi @ 7.5 psi of boost.
I thought you had the E-manage tuned?
Slow I could not comunicate with the Emanage I used to laptop and always have problems so I am back to Stock Comptech.
I got higher fuel flow than Comptech uses in their kit.
So I have to run the FMu and the Sx FRP at the same time?
Just to hijack your thread for one quick question....
I am planning on a Comptech supercharger with aftercooler int he near future. Can it be installed safely with no additional management, (using the comptech computer) or is it imperative that I installed some other form of management(ie emanage or aem).....by safe, I mean occasional 9000rpm shifts, and for the motor to last/
Thanks.
Thanks.
Juan, I don't think you have to add the SX regulator. The static fuel pressure the Comptech FMU is adjustable.
There has to be a answer to your com problem with the E-manage. I just don't know what it is, I've never had my PC not communicate with the E-manage.
demonderrick
Jun 8, 2005 11:38 PM
