comptech sc question
Old Sep 15, 2004 | 09:11 PM
mikecl713's Avatar
Default comptech sc question
when u level the sc pulley and the crankshaft sc pulley.
is the sc pulley slightly more towards the front of the car?
or should they be equal plane?
Old Sep 15, 2004 | 09:54 PM
AusS2000's Avatar
They should be in line of course but I've never really checked. I expect I would have noticed if they were out of alignment.
As you are using a smaller pulley are you sure it is the same offset as the original?
Old Sep 15, 2004 | 10:16 PM
xviper's Avatar
Driving pulleys and driven pulleys need to be in the exact same plane or the belt will ride to one side and try to run itself off one pulley or the other or both.
Old Sep 15, 2004 | 10:19 PM
mikecl713's Avatar
the offset is the same as the original...
aus2000 could u check urs plz?
Old Sep 15, 2004 | 10:45 PM
AusS2000's Avatar
Just checked it. Mine's about as even as I can check with a ruler and a torch.
Old Sep 16, 2004 | 07:49 AM
Ztec's Avatar
Did you buy your kit new or used? Mine was new and the mounting hardware was "zip-tied" together so there was no question on how it was mounted! All the pulleys run true there is no offset or there is a problem! Make a "Plumb-bob" out of a piece of string and a washer and let the string hang below the crank S/C pulley and line it up with the blower pulley to see if it lines up!
rikhemi
Jul 18, 2010 07:12 AM
WindchaserS2K
Oct 21, 2007 02:17 PM
johninator
Jul 23, 2006 03:47 PM
D-S2K
Dec 16, 2004 03:39 PM
