Coolant Leak & Over heat
Old Jan 12, 2016 | 03:26 AM
Templetoes's Avatar
Angry Coolant Leak & Over heat
So,
This is my first post, I've been a lurker for a while. However, today while driving to work my S (2000 AP1, 86k miles) got up to 4 bars on the gauge. I thought it odd but kept on my commute. Literally, a 6 mile commute. Nothing too strenuous. Got about a mile from work, and it hit 5 bars. I immediately pulled over and turned it off. However, in the time it took me to pull over, I also had this weird "knocking" noise come up. Not like engine knock. It wasn't relative to the engine, but more so me driving on the road. Not sure how to really explain it any better. After I got pulled over, I popped the hood, turn the key to ACC, and proceed to see what was up. No coolant in the reservoir so I looked under the car and there was coolant beginning to leak. I'm not sure if the "knocking" I heard earlier had anything to do with the coolant or not. Gonna try to put some water in there and drive it a half mile to a garage later on today. Figured I would stop by here and see if there were any words of wisdom. or anyone with relative stories.
Old Jan 12, 2016 | 03:34 AM
Templetoes's Avatar
++Just to add, on initial start up this morning, it was a rough start. it was Cold as well, roughly 28 Degrees.
Old Jan 12, 2016 | 05:03 AM
Slowcrash_101's Avatar
First step is to determine the source of the leak, is it the pump? A hose? Head gasket? Radiator, radiator cap? Loose petcock valve?
Old Jan 12, 2016 | 05:08 AM
Templetoes's Avatar
Well, I couldn't really see "where" the leak was coming from. It was still extremely dark out, and I had to get to work. So, I'll be going back later on afterwards and checking to see where it looks to be coming from.
Old Jan 12, 2016 | 08:12 AM
Templetoes's Avatar
[media]http://imgur.com/p16Qb7W[/media]
So, I filled up the radiator after it was completely flushed out this morning, drove it slow back home, didn't over heat at all until I came to a stop at my house, at that point it started POURING the water I had put in there to temporarily get it home. Like a river. I also have NO hot air whatsoever coming out from the inside of my car.
Can anyone help?! I'm lost. New radiator? New heater core? Thermostat?
Old Jan 12, 2016 | 09:25 AM
flanders's Avatar
You need to find the source of the leak.
Also stop driving it until you have it fixed it and got all the air out of the system.
Old Jan 12, 2016 | 11:17 AM
Templetoes's Avatar
I've already stopped driving it. Gonna get home and pop the shield underneath and take a look around to see where the leak could be. It should be an obvious fix, it's not really a leak as it is a flood after coming to a complete stop.
Old Jan 12, 2016 | 02:51 PM
Chuck S's Avatar
Search for the threads about getting all the air out of the cooling system. Requires more than filling the radiator.
-- Chuck
Old Jan 12, 2016 | 03:12 PM
s2000ellier's Avatar
buy, rent, borrow a coolant pressure tester. use it in your garage with the door shut get it as quiet as you can. pressurize the system and listen for the leak. this is the simplest way to find the leak.
something like this, make sure it fits your radiator.
http://www.amazon.com/Stant-12270-Co.../dp/B0002SRGWU
manonastick
Jul 23, 2015 02:57 PM
surfer_crx
Oct 17, 2013 02:16 PM
jdm_Justin
Aug 1, 2012 09:48 PM
s2k809
Oct 19, 2010 08:59 PM
st4rk
Jun 10, 2007 10:38 PM
