Coolant routing lines
I am trying to determine if the S2000 coolant system would work in this configuration or if I would have to relocate my thermostat.
Basically I want to connect the two smaller lines that normally join at the water neck of the intake manifold. These two lines come from the top of the water pump housing and the top line from the heater core.
The reason for all this is the Kinsler ITB I have uses a single 12AN port and I've been unable to locate a OEM style water neck that I could use.
