Coolant temp gauge AEMv2
Old Oct 24, 2016 | 05:14 PM
UH-60DRIVER's Avatar
Default Coolant temp gauge AEMv2
My stock coolant temp gauge is reading maxed out all the time with my AEMv2. If I log on to my laptop I can see the true reading. Why would my EMS read correct but not my factory gauge?
Old Oct 24, 2016 | 05:58 PM
S_DosMil's Avatar
Not sure if it's the same I'm sure you could google it but the AEMv1 had a temperature correction made by Modifry when using the standalone.
Old Oct 24, 2016 | 11:28 PM
riceball777's Avatar
Your ems is is broken and needs to be sent to aem to have it looked at. I have been running the aem series 2 for many years. It would run my stock dash coolent gauge fine but one time it just started reading maxed out all the time. Since aem is very close to me I took it to them to have them check it out. They said the chip inside that runs the dash coolent gauge was messed up and they replaced it under warentee.
Old Oct 24, 2016 | 11:33 PM
The aem version 1 does not run the stock coolent temp gauge on the dash. You needed the modifry aem temp fix so the aem version1 can run the stock temp gauge.
This is not the case with the aem version 2. The aem version 2 is suppse to run the stock coolent dash gauge just fine. I know mine does.
Old Oct 25, 2016 | 08:46 PM
Ya, mine ran fine for a year or so then after a installed my new engine it reads maxed out. I'll email AEM to see there thoughts. Hope I don't have to send it in but it sounds like the case.
JspecVtec
Sep 14, 2012 02:05 PM
riceball777
Jan 2, 2011 03:51 PM
roy365
May 4, 2009 03:16 PM
Toad17
May 23, 2008 05:49 PM
Kondor999
Jan 25, 2008 08:43 AM
