Coolant temp sensor thread spec
Old Mar 23, 2015 | 08:02 AM
06Estukay's Avatar
Default Coolant temp sensor thread spec
Hello, does anyone know the thread spec for the coolant temp sensor located on the intake manifold?
Thanks!
Old Mar 23, 2015 | 08:34 AM
zeroptzero's Avatar
Do you have one out of the vehicle ? I never see them list the thread size for sensors in the manual or on majestic Honda's parts site.
If you have a sensor out of the car go to a place that sells fasteners and see what size metric nut fits over the threads, even at Canadian tire.
Old Mar 23, 2015 | 08:59 AM
06Estukay's Avatar
Hey Joey, yah it's out of the vehicle. I suspect it's a BSPT thread. I'm trying to fit an aftermarket sensor in the stock location for a custom ecu.
Old Mar 23, 2015 | 09:06 AM
Habitforming's Avatar
Most of Honda's sensors do seem to be BSPT. You have to be careful because NPT appears to work, but won't get a good seal. I would do as JFusionsaid and take the sensor to a specialty fastener store like Fastenal.
Old Mar 23, 2015 | 10:55 AM
06Estukay's Avatar
Yep, no way I was gonna try screwing an npt sensor in there. Was gonna get a brass or stainless steel adapter for it.
Old Mar 24, 2015 | 04:14 AM
99SH's Avatar
I believe it's M10x1.25 (the same as fan switch on the radiator for pre-MY06)
Old Mar 24, 2015 | 04:21 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Definitely not pipe thread.
I can post it later this morning...
Old Mar 24, 2015 | 07:26 AM
zeroptzero's Avatar
I remember last time I worked with one it threaded in pretty easily by hand, it didn't feel like a pipe thread. I am always surprised this sensor doesn't use any sealant, o-ring or washer, yet it remains leak free.
Old Mar 24, 2015 | 08:14 AM
s2000ellier's Avatar
use a M12x1.5 tap
Old Mar 24, 2015 | 10:23 AM
Billman250's Avatar
Top Answer: 1
Originally Posted by s2000ellier
M12x1.5
Correct, 100%. The sensor seals with an oring at the base of the threads.
sohc_mshue
Jul 22, 2012 01:27 PM
ninekallday
Mar 18, 2010 07:42 PM
Envied
Aug 19, 2009 09:34 AM
dsddcd
Mar 5, 2009 07:33 PM
