Core Exchange?
Old Dec 4, 2005 | 08:02 AM
Black Sheep's Avatar
Default Core Exchange?
can someone explaine a little throttle bodies in regards to the "Core Exchange" programs some people are running.
I take it the core is a expensive peice to make from new?
Which part is the core? Is it the part behind the butterfly?
Old Dec 4, 2005 | 07:22 PM
S2KSpaYellow's Avatar
The core is your old throotle body. They will rebuild yours to make the next one to sell. Yours will be bored and a new butterfly will pe put in. They will then sell it to someone and ask them for a core....the cycle goes on.
Old Dec 5, 2005 | 05:31 PM
Right I see thanks for that.
Are there are any limitations to using a standard throttle body and having this milled out to Spoon Specs or like the J's Racing one?
Are they doing something special to thiers that a local busiiness couldn't do as they charge more, or is it simply because you're getting a new throttle body added to the price?
Old Dec 6, 2005 | 07:29 PM
There is not much of any difference other than the bore size. The Sppon or Js is already a larger bore (70mm?) than stock. There would be no need to increase the bore on those two. A stock is smaller so it can be bored to the larger size and be about the same as the Spoon/Js.
Old Dec 7, 2005 | 05:15 PM
Thanks for that, think I'll take that route then for the TB.
caleb2483
Apr 9, 2011 04:06 AM
pinoyk20
Mar 13, 2009 06:09 AM
2QYK4U
Jul 13, 2007 04:38 AM
kayvan_pour
May 28, 2005 12:50 PM
