correction: p1456 or p1457
Old Apr 30, 2010 | 10:51 PM
starchland's Avatar
Default correction: p1456 or p1457
Hey guys, the other day my cel went on. I pulled it via blinking light - 9 long blinks, which I believe is code 9 if im doing it correctly.
No drivability problems at all. I reset the ecu and unhooked the battery, then I drove about 50 km no problem, then the light came on again. I cant find much. Im not sure where this sensor is located either. Need advice. thanks.
Old May 1, 2010 | 05:07 AM
SpitfireS's Avatar
Code "9" is not in my manual.
7, 8 and 10 are.
Maybe get the code with an OBDII?
Old May 1, 2010 | 07:08 AM
spets's Avatar
I believe long blinks are 10s, so it would be a Code 90. In my manual it shows that it could be either P1456 or P1457, which is an EVAP system leakage of either the fuel tank system of the canister system.
Make sure the gas cap is good and tight.
Old May 1, 2010 | 10:18 AM
starchland's Avatar
ok. I must have been confused with the obd1 system. The blinks were about a second or so. I will reinvestigate thanks everyone.
Old May 3, 2010 | 09:49 AM
starchland's Avatar
Okay, so upon looking at it again, it is a code 90 - P1456 or P1457 like stated above. I am looking into the gas cap as the problem.
does anyone know if a scan tool will distinguish between 1456 or 1457?
JohnnyAnonymous
Feb 9, 2009 05:00 AM
dyhppy
Jul 17, 2007 07:43 AM
nosyajg
Sep 26, 2006 09:56 AM
jimi
Apr 18, 2006 02:35 PM
Empedocles99
Jan 11, 2005 04:28 PM
