Crankshaft end play..
Another option if if your bores are still round and relatively in spec is to bore and hone to .25 oversized and get OEM honda Oversized pistons.
i ended up using a better block as my walls were scratched along the length of cylinder and cylinder #1 and #4 was out of round. Yeah I wouldn’t sleeve and it costs a lot more since you’ll need new pistons as our OEM pistons/rods etc as they are not compatible with a steel liner.
From what I have been learning from this site. Sleeving is out of my solution for a rebuild and seeing that the blocks dont last long. I think i am going to put this block back together and see what happens. If it fails i will look for a used block or find a used motor. Thank you for your help!
afwfjustin
Jun 4, 2009 12:23 PM
