Crankshaft replacement
Old Jun 11, 2007 | 07:49 PM
Spnshfirefighter's Avatar
Default Crankshaft replacement
bought this engine on ebay and its got some problems. main bearings are shot. I am going to pull the engine out of the car again and replace them. as well as the rod bearings while im at it. I have an AP1 and I have a 2.2l crank in my garage that I am thinking of swaping on as well. will this work? does that increase my displacement 200cc +? anything else I should switch out while the block is upside down and getting some work down. I have some horrible knocking sound and there were metal (gold) colored shavings and the bottom of the oil pan so I think I should replace everything I can without taking the head off. I know the head is fine as well as the seals on it, just the valves clearance need to be adjusted. I have half the oil pressure that I should and a couple mechanics think its the main bearings for sure. any input on this would be great from the gurus of engines. im learning alot by doing all this work.
thanks guys
Old Jun 11, 2007 | 07:58 PM
AusS2000's Avatar
You'll need new rods too. The 2.2 crank has a longer throw. With stock rods the pistons would rise above the deck of the block and hit the head.
Old Jun 11, 2007 | 08:52 PM
Eluded's Avatar
ohhhhhhhhh the pain
Old Jun 12, 2007 | 03:12 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
I'd be real wary of the gold flakes. Sounds like the cylinders are junk.
_brandon
Mar 3, 2014 03:34 PM
kt6089
20
Aug 7, 2009 07:08 PM
Spnshfirefighter
Jun 24, 2009 06:41 PM
Spnshfirefighter
Jun 22, 2009 03:30 AM
Empedocles99
Oct 2, 2005 09:51 PM
