Cross threaded Into the block
Old Feb 15, 2025 | 12:10 PM
smeeze's Avatar
Default Cross threaded Into the block
Hello I’m looking for advice on a mistake I made. Today I was installing my new TCT and one of the bolts kept spinning. After I realized something was wrong I took the bolt out and saw threads/shavings from inside the block. I don’t really know how to go about this can someone help.
Old Feb 15, 2025 | 12:15 PM
noodels's Avatar
you need a helicoil repair kit
Old Feb 15, 2025 | 03:08 PM
cosmomiller's Avatar
Top Answer: 1
While you are at it, use the new OEM TCT as a core and send it to Billman for one of his improved TCTs.
Old Feb 15, 2025 | 05:10 PM
B serious's Avatar
Need more info
Was your bolt too short? This couldn't happen via over torque because you'd break the bolt before messing up the thread.
Did it ever get tight?
My guess is you used a bolt which was too short or too long.
The solution to your problem depends on how this happened.
Old Feb 16, 2025 | 05:15 AM
Chuck S's Avatar
Stripped threads in aluminum blocks are common enough that this should be repairable.
TCT bolts only require 8.7 lbf-ft torque. Trying to force a too-long steel bolt into a too-short hole in an aluminum block can easily strip the threads in the block when the bolt reaches the bottom of the hole and keeps turning.. For example Billman's TCT has a thinner flange (so overall depth of the hole is shallower) and comes with shorter bolts to prevent this.
-- Chuck
Old Feb 16, 2025 | 07:54 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
PM me your cell number.
Which bolt, front or back?
For the record, you are over tightening the bolts by 3X more than needed.
Dungle
Jul 14, 2017 09:17 PM
taylorsmith831
Aug 9, 2015 04:07 PM
Ek_Jak
Nov 27, 2014 06:14 PM
GoFaassttt
Oct 7, 2009 07:57 AM
a6s7d8
Jan 24, 2005 02:23 AM
