Lower Block removal Problem
Old Aug 8, 2015 | 01:50 PM
taylorsmith831's Avatar
Default Lower Block removal Problem
I need to pull my lower block from my upper block to remove crank and get the block re sleeved, all bolts are loose. HOW THE HECK DO I SEPERATE THIS SUCKER? Any tricks i have a rbber and wooden malet that have done nothing.
Old Aug 8, 2015 | 02:58 PM
Slowcrash_101's Avatar
You mean the head from the block? Are you talking about the crankshaft girdle? Main caps? You're making a very vague statement making it almost impossible to help. Have you removed the engine from the car? Is the transmission still attached to it?
dagle's Avatar
There's a spot to prybar it from. You removed all the 10mm bolts as well, correct?
Old Aug 8, 2015 | 03:17 PM
99SH's Avatar
All the bolts are loose? They need to be removed (the headstuds). Simply pull/push on the spark plug tubes for leverage and rock it back/forth. Don't forget about the ground bolt behind the cylinder head.
Old Aug 8, 2015 | 03:33 PM
dagle's Avatar
he means the girdle i think since he mentioned crank
Old Aug 9, 2015 | 03:56 PM
bluemetals2k's Avatar
Hit the cast tabs on each side with a hammer lightly a few times you will hear a change in pitch when the block gets loose and will easily pull apart
Old Aug 9, 2015 | 04:07 PM
windhund116's Avatar
Did you loosen the bolts in a series of steps, working from outside toward the inside? To prevent the body from warping.
D1sclaimer
Dec 3, 2023 10:13 AM
_brandon
Mar 30, 2014 11:26 AM
GoFaassttt
Oct 7, 2009 07:57 AM
ChefJ
May 18, 2009 05:11 AM
natureal
Apr 17, 2006 07:49 AM
