Cruise Control not working
How do you guys remove the clutch switch? Theres a fusebox nearby, and I cannot get my fingers behind the clutch switch to remove it. And jeez, what an insanely difficult place to do work, even with the chair moved all the way back. And BTW, the white nipple for both clutch and brake is still intact so that's not the problem.
The clutch switch is held in the bracket with a single nut. You remove the nut and the whole thing comes out, then you can remove the harness connector.
So no harm to the harness, even though you have to twist it quite a few times while spinning the clutch switch?
Originally Posted by st.ryder64' timestamp='1441799258' post='23741546
[quote name='steven88' timestamp='1441769939' post='23741390']
[/quote]
I don't recall if the switch threads into the bracket or not (most of the blood in my body was in my head in the position I was in), but obviously if it does, you'll hafta pull the connector prior to unscrewing it out.
Originally Posted by steven88' timestamp='1441839694' post='23742365
[quote name='st.ryder64' timestamp='1441799258' post='23741546']
[/quote]
[/quote]
The clutch switch is threaded and is screwed into a bracket with a welded nut. You can see pictures here, courtesy of zachberry
https://howtune.com/articles/278-fix...0150906-173645
So if you have to pull the connector first....how the heck do you do it? Theres a fusebox nearby and its impossible to fit your fingers behind there to pull the connector.
https://howtune.com/...20150906-173645
Haha, yeah I was thinking you need some kind of tool for it. Because I can't see any normal adult hands being able to fit down there. My hands are nowhere near large, and even my hands are way too large to fit in there. I'm surprised your fingers could fit without using a tool...lol
This thread is old, but a good place to post. If your cruise control is inoperative, check for a missing white plastic bumper button that contacts the clutch switch. The one that the clutch pedal sits against when the clutch is in the released position.
If it's missing, the cruise control will not arm.
