Cruise control not working
Old 12-06-2019, 04:56 AM
winter5470's Avatar
Default Cruise control not working
I have a 2006 S2000 with drive by wire.
The cruise control recently stopped working.
On occasion it would drop out of cruise if I hit a bump.
Then it stopped working all together.
When I press the button on the dash - it lights up.
But if I press set or resume on the steering wheel I get no throttle response.
Everything else works fine - lights, horn, etc
I searched the forums but found very little about non working CC in the drive by wire models.
Any thoughts of things to check?
Thanks
Kurt
Old 12-06-2019, 05:15 AM
theprophet36's Avatar
Check the clip underside of steering column? Mine isn't DBW but when the CC didn't work I found that clip wasn't fully in.
Old 12-06-2019, 05:21 AM
Billman250's Avatar
Received 1,307 Likes on 795 Posts
First culprit is the plastic white button on the clutch pedal that activates the cancel switch. They get brittle and break, fall to the floor, rendering the cruise cancel switch inoperative.
You could get a stick-on cushion (computer monitor cushion feet) to fix it.
Old 12-06-2019, 06:21 AM
winter5470's Avatar
Good idea!
Had the one on the brake pedal go last year.
I hope that is it!
Kurt
Old 12-06-2019, 06:26 AM
winter5470's Avatar
Prophet36... What clip under the steering column???
Do you have a picture?
Kurt
Old 12-06-2019, 02:07 PM
winter5470's Avatar
OK......I am not sure this is OEM.
Old 12-06-2019, 02:10 PM
winter5470's Avatar
Old 12-07-2019, 04:05 AM
Billman250's Avatar
Looks like the white button broke, and was replaced with the black plastic tree clip. Be sure it is pushing the button all the way in while at rest.
Old 12-08-2019, 08:48 AM
winter5470's Avatar
Replacing the clutch stop did not help.
any other ideas?
i did find 2 loose wires...see picture.
i assume they are just orphans and don’t go any where?????
Old 12-08-2019, 09:01 AM
winter5470's Avatar
There is no connection to the cruise control switch!!
any idea what color wire goes there???
Quick Reply: Cruise control not working
