cylinder 4 low compression.
I recently purchased an s2k and noticed that it idle'd a bit rough.
Took it into a local (trusted) shop to take a look at it. They suggested cleaning the injectors and having valves adjustment.
Did that, idle is still rough (it holds RPM's, but you can feel it in the cabin a lot).
So we did a compression test and it turns out that #4 is low (around 134). The others are at 175-180.
He determined that the leak is either from scoring in the cylinder (he put oil in it), or a bad gasket (both very common for #4).
My question is, could it be something else? Should i look for anything else?
I plan to take it to another mechanic, purely to get a second opinion.
The car has no CELs (in the 700miles ive had it), and no smoke. 2007 71k ODO.
F20CZJ
Oct 31, 2015 05:32 AM
05TurboS2k
Feb 17, 2012 02:34 PM
