Cylinder Head inspection
Old May 30, 2007 | 07:33 PM
mxt_77's Avatar
Default Cylinder Head inspection
I need to buy a used head, and I'm wondering what I should look for when purchasing used. I guess I'd first check for obvious valve damage & cracked retainers. Can I check for warpage? How do I do that? How much (if any) is acceptable? What else should I look for?
Old May 31, 2007 | 03:29 AM
chris_barry's Avatar
Get a straight edge (metal ruler) and a torch. Use the torch to gauge if there is any warp by holding the edge of the ruler against the head an use the torch to try and shine light through the contact patch.
Check for any knocks or gouges in the area where the fire rings seal around the combustion chambers.
You can use the torch by shining it into the ports and looking around the valves to see if any are bent.
Good luck
Chris
Old May 31, 2007 | 05:08 AM
mxt_77's Avatar
And by "torch", you really mean "flashlight", right?
Thanks for the tips!
Old May 31, 2007 | 05:12 AM
90crvtec's Avatar
[QUOTE=mxt_77,May 31 2007, 08:08 AM]And by "torch", you really mean "flashlight", right?
Lair
Sep 10, 2017 05:03 AM
jimknapp
Aug 27, 2010 09:06 AM
chris2k03
Jul 23, 2009 09:08 AM
S2oooNvegas
Mar 14, 2007 09:53 AM
lude9285
Feb 26, 2007 06:52 PM
