valve job
Old Feb 10, 2007 | 09:28 PM
lude9285's Avatar
Default valve job
My check engine light has been on forever with multiple misfire codes and eventually found out its due to leakage around intake valves on cly 1. So im just going to do an entire valve job to get everything back to normal. Would you guys recommmend just working with the head i have...new valvetrain..or just looking for a used head. I also had a question about head gasket/headbolts....should i just go from dealership? Looks a little pricy..from local dealership any sites to check for cheaper oem honda parts
Old Feb 11, 2007 | 03:30 AM
CoralDoc's Avatar
Hardtopguy
If the part isn't listed on the website, give them a call.
Old Feb 11, 2007 | 05:43 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Jacko is selling a perfect head in the For Sale Forum.
Head bolts: You can use the old ones, if they've never been touched before. However, new head botls get an extra 1/4 turn, So I'd recommend new Honda bolts. Get a Honda head gasket as well.
I'm curious about the diagnosis....are the valves bent, or burnt? s2k's usually never bend intake valves, only exhaust. And the only way to burn them, if your stock, is to tight of a valve adjustment. They come barely loose from the factory.
Old Feb 11, 2007 | 05:48 AM
Billman250's Avatar
Top Answer: 1
https://www.s2ki.com/forums/index.php?showtopic=460297
Here's the head....I pulled it myself to put in a race head, I can vouch it is in perfect running condition. If it were me, I wouldn't even touch it, I'd bolt it on the car as is.
THEN.....you can get a second opinion on your head, fix it if needed, and sell it to recoupe some cash.
Old Feb 26, 2007 | 06:52 PM
lude9285's Avatar
i think im going to just rebuild my head, with the supertech valvetrain. Then it will all new/rebuilt. Does anyone know of a good machine shop or place i could send my head once i pull it off to get the valvejob/rebuild? I live in western NY, Buffalo area
Silver_Bullet_S
Oct 6, 2018 01:15 AM
Lair
Sep 10, 2017 05:03 AM
Tech2uned
Mar 25, 2012 11:38 PM
chris2k03
Jul 23, 2009 09:08 AM
DezodWest_S2k
Jul 11, 2008 06:20 PM
