cylinder head rebuild DIY?
Old Feb 16, 2009 | 12:52 PM
jonnys2k01's Avatar
Default cylinder head rebuild DIY?
is there a diy for this... or a manual that has specs and so on to rebuild the head..
my main concern is the valve adjustment.. i know the specs already.. but they are for when the head is warm or at operation temp... but when the heads off the car.. thats a bit impossible to achieve... so what specs should i set them valves to when cold.... keep in mind these are new valves.. new retainers... and new springs..and new seats
all brian crower...
should i replace valve guides?
any info would be great...
thanks guys
Old Feb 16, 2009 | 01:31 PM
Back S2k's Avatar
as far as i know these are the cold specs and this is what i went by when i adj my valves .008-.010 intake and .010-.011 exhaust.
Old Feb 16, 2009 | 01:45 PM
jonnys2k01's Avatar
those are the warm specs.. by the manual.. so maybe their the same... then why would they be listed as warm... weird... damn hondas.. tricks are for kids... this car is mind boggeling at times...
Old Feb 16, 2009 | 03:18 PM
RedY2KS2k's Avatar
No, the S2000 manual states the engine is to be cold when the valves are adjusted.
Old Feb 16, 2009 | 03:27 PM
Slows2k's Avatar
You can't effectively adjust the valves with the head off the car.
The rocker shafts and stands need to be remove to access the head bolts, and the final torque on these bolts will change your valve adjustment.
Old Feb 16, 2009 | 04:45 PM
jonnys2k01's Avatar
i understand that.. but theres no exact standard when the heads off... oof how to do it.. guess each engine when initially built went threw that lengthy ass process of valve adjustment... alrite thanks
Old Feb 16, 2009 | 05:13 PM
Slows2k's Avatar
There is no standard to do it off car because it can't be done correctly....
Silver_Bullet_S
Oct 6, 2018 01:15 AM
cmc600rr
Nov 17, 2015 04:11 AM
tidus888
Jun 2, 2011 12:51 PM
jonnys2k01
Mar 23, 2009 10:51 PM
lucky77
May 6, 2008 12:34 PM
