Cylinder scratch
Old Mar 12, 2012 | 01:58 PM
BBV S2K's Avatar
Default Cylinder scratch
Isn't bad it's just like a Paint clear scratch.. even if you try to scratch it with your nail, your nail wont get stuck...
will this affect my block performance?
Old Mar 12, 2012 | 02:03 PM
BBV S2K's Avatar
I took the head off after this problem....
https://www.s2ki.com/s2000/topic/931227-ap1-problems/
car was running good but I decided to take the head off and see the work they did... I have experience as a mechanic but haven't work EVER in a S2K...
just V8s
Old Mar 12, 2012 | 03:08 PM
BBV S2K's Avatar
bump
Old Mar 12, 2012 | 04:07 PM
BBV S2K's Avatar
BUMP NEED HELP BEFORE I PUT EVERYTHING BACK
Old Mar 12, 2012 | 04:29 PM
steven975's Avatar
If the compression is fine, I don't think those will impact the performance of your block. If you can't even catch a nail on them, I don't think you have a problem.
You may have more oil consumption, but a compression test will really be the determinant. Look for consistency over nominal readings.
Old Mar 12, 2012 | 06:00 PM
BBV S2K's Avatar
Im so stupid that Didnt took comp of any of them BEFORE taking everything off...
Old Mar 12, 2012 | 09:31 PM
BBV S2K's Avatar
TTT
Old Mar 13, 2012 | 07:52 AM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Normal s2k motors dont look like that. The cylinders will be spotless. What year is the engine? That is definitely due to lack of lubrication at some point.
I have a motor here with 120k and a spun bearing due to low oil and the cylinders are perfect. One fine black line at the most.
Old Mar 13, 2012 | 07:53 AM
Billman250's Avatar
Top Answer: 1
if they dont catch your nail you will likely be ok.
Old Mar 13, 2012 | 09:26 AM
BBV S2K's Avatar
Its an 02' Ap1 with 95k right now...
Problem is that spark plug tread went bad and the spark plug fell and piston hit it out of the hole... and some pieces of the coil melted inside and went to the piston... you can feel the scratch but they arent that big... maybe a small honey will fix it?
