Dashboard removal
I would like to remove my dashboard so that holes can be cut into it and my Defi gauges can be installed. According to the Helm's manual the steering column is supposed to be removed as one of the steps. Is that really necessary?
Originally Posted by Slows2k,Aug 18 2007, 04:09 PM
Yes, the column runs through the dash. It needs to be removed to get the dash out in 1 piece.
Any advice?
Originally Posted by Slows2k,Aug 26 2007, 09:13 AM
Pull the seats out for more room.
Pull the bolts that hold the column to the dash brace and let the column drop to unplug the connectors.
Please bare with me hear and I am still in the learning process.
Here are some pics:
I think the last couple of pics show the three connectors which need to be disconnected.
P.S. I am not happy with the way some of the wiring looks (not clean/zipped tied together). Once I have everything removed, I am going to try and clean it up some.
Originally Posted by Slows2k,Aug 26 2007, 09:30 AM
Pics would help. What is easy for me to access and unplug can be quite difficult for others. I've been working on this stuff for too long
The yellow SRS connectors usually have a black release sleeve which has to be pulled back before they disconnect. Directions are in the SRS section of the SM.
The white connectors in the pic have a release tab on the back side of the male connector which has to be depressed to get them apart. Use a small screwdriver to depress and wiggle them apart.
