Data Logging question
Old Oct 17, 2002 | 08:50 AM
KYS2000's Avatar
Default Data Logging question
Is there other alternative to datalog in the S without buying an EMS?
Please list them
Old Oct 17, 2002 | 01:04 PM
davepk's Avatar
A number of us use this...
http://www.obd-2.com/
Old Oct 17, 2002 | 08:44 PM
KYS2000's Avatar
Do I just buy the 122 package for ISO. Then how hard is it to setup for datalogging?
Old Oct 17, 2002 | 09:33 PM
davepk's Avatar
Do a search on "OBD" and you'll find alot of info on how to datalog engine operating parameters. I do it from time to time using a cable and software i got from the above website. When i install a mod on the car i'll perform a datalogging session just to see how the ECU is reacting to it. And yes the $122 ISO model is all you need. Just a heads up... I've tried unsuccesfully to use it with a rs232->USB converter so your computer will need a rs232 DB9 connector. You should also realize that the parts that make up the connector probably cost no more $5 or $6...
Old Oct 18, 2002 | 07:13 AM
KYS2000's Avatar
I thought it plugs into the serial port of the computer. So you have it plugging into the USB Port? If so, where do I find the parts to make up this adapter?
Old Oct 18, 2002 | 07:49 AM
davepk's Avatar
Yes it does plug into a rs232 port on your computer. I tried a rs232 to USB converter and it failed to work. Could have been something i was doing wrong on my end tho.
Old Oct 18, 2002 | 11:21 AM
KYS2000's Avatar
So it will work if I just plug it into the 9 pin rs232 serial port on my laptop right?
Old Oct 18, 2002 | 11:45 AM
davepk's Avatar
yes
Old Oct 20, 2002 | 07:44 PM
S2K_LA's Avatar
Does the cable that they use have any electronics on it? Or is it just the OBD adapter with a cat 5 cable into a serial adapter?
Old Oct 20, 2002 | 08:00 PM
schwett's Avatar
it's just a cable, no electronics.
BrewCityBoozer
May 22, 2012 07:15 PM
vspc2nr
Apr 9, 2010 07:17 AM
vspc2nr
Mar 30, 2010 04:02 PM
2gr84u
Jun 28, 2008 09:07 PM
