dc5 type-r brembro direct bolt on on s2k?
Old Mar 20, 2008 | 08:33 AM
fastmiata's Avatar
Default dc5 type-r brembro direct bolt on on s2k?
anybody know?? thanks
Old Mar 20, 2008 | 09:12 AM
Slows2k's Avatar
No. Different rotor offset.
Old Mar 20, 2008 | 09:29 AM
B serious's Avatar
Doesn't the USDM RSX use the same rotors and pads as the S2000? If that's true, then the spindles are most likely the same between the DC5 ITR and USDM Type S.
So the rotor "offset" may be different, but the caliper bracket, and caliper should fit an S2000....meaning that the rotor offset would be arbitrary.
The rotor offset should be the same anyway.
Iduno...the USDM RSX Type S uses the same rotors, and IIRC, the same calipers as the S2000, right?
I'd figure the brembos bolt right onto the USDM RSX's spindle??
Maybe I'm wrong.
Old Mar 20, 2008 | 09:49 AM
coldrsx's Avatar
^i also thought the Type-s shared the same caliper and rotor set?
Old Mar 20, 2008 | 12:58 PM
VAD's Avatar
VAD
There are no rotor or caliper part numbers that fit both S2000's and RSX's (any model RSX). The RSX-S can use the same brake pads as the S2000. The rotor offsets are roughly .3 inch different. So, to answer the question in the thread title, no.
Old Mar 20, 2008 | 02:23 PM
Slows2k's Avatar
All of the OEM calipers and rotor part #'s are different between the RSX-S and the S2K
The front pads can be swapped between the 2 calipers
keung
Oct 1, 2015 08:41 AM
GT 52DDD
Nov 4, 2010 08:37 AM
XXX240
Jul 26, 2007 05:58 PM
GrimReaper
Nov 14, 2005 06:04 PM
