HONDA INTEGRA DC5 FRONT BREMBO CALIPERS
Old 10-06-2006, 11:01 PM
XXX240's Avatar
Default HONDA INTEGRA DC5 FRONT BREMBO CALIPERS
Hi Guys,
Will DC5 Brembo calipers, direct fit instead of our calipers ?
Have anybody done this...
Cheers
Nev
Old 10-07-2006, 01:24 PM
Slows2k's Avatar
The rotor's offset from the hub is different between the RSX and the S2k. Stock calipers will not swap. The only stock part that will swap is the pads. Who knows if the Brembo equipped RSX uses the same rotor.
IIRC when this came up before the answer is no, doesn't fit.
Old 10-08-2006, 10:42 PM
XXX240's Avatar
Thanks
Old 10-09-2006, 11:42 AM
Luder94's Avatar
Which Brembo's are you talking about DC5 Brembo or DCRR Brembo.
The offsets on the Japanese Integra type R (RSX type R, had it come to the states) is different than the "plain, Jane" DC5.
Old 10-16-2006, 12:19 AM
XXX240's Avatar
Stock DC5, RSX model. Front brembo calipers.
Old 07-24-2007, 09:43 PM
sketch's Avatar
Has anyone tried this or have an answer as to weather or not a DC5R caliper would fit on our cars?
And if so what would be required IE: Custom brackets or can they be ordered from Brembo.
Old 07-25-2007, 02:20 AM
Marin's Avatar
Why would you want to change?
Old 07-25-2007, 05:41 AM
nearwater4me's Avatar
Maybe becuz the Brembos are way better than stock brakes and he has a set lying around for RSX application.
Dan
Old 07-26-2007, 05:50 AM
Marin's Avatar
I don't see how the brembo calipers could be much better, but to each their own.
Old 07-26-2007, 06:27 AM
LuckyStar's Avatar
Just a guess since I have never seen DC5R brembo's perform in person,
But they should be better because it is a 2 piston caliper which provides equal pressure over a larger surface area.
And they are fixed calipers which improves brake feel because the pads are closer to the rotor as well as it provides equal force against both sides of the rotor at the same time (not so on floating calipers).
All of that helps make a car brake quicker.
And the OEM S2000 brakes are really nothing special. Same thing as any other Honda brakes just sized to fit our car.
Quick Reply: HONDA INTEGRA DC5 FRONT BREMBO CALIPERS
