de-badging question
Old Feb 7, 2005 | 06:15 PM
scubasteve's Avatar
Default de-badging question
Ordered some JDM diffusers and side markers and would also like remove the "S2000" badge to finish the smoother look.
Does anyone know whats behind there; studs & holes like the front/rear, or just glue. How did you remove them?
Old Feb 7, 2005 | 06:22 PM
scubasteve's Avatar
anyone?
Old Feb 7, 2005 | 06:23 PM
slipstream444's Avatar
My car currently has the JDM markers and headlights and I had the S2000 badges removed.
The badges are attached by 3M adhesive tape ... no holes or screws. I would talk to your local body shop about removing the badges without damaging the paint, or have them do it.
Good luck.
Old Feb 7, 2005 | 06:26 PM
scubasteve's Avatar
is that what you did? body shop that is
AP2kyle's Avatar
Just glue on the sides.
I used dental floss to tear em off. Then picked at the left over adhesive for hours until it was ok to use rubbing alcohol to clean off the rest. Car's paint was ok. After all, I have black.
Old Feb 7, 2005 | 06:29 PM
scubasteve's Avatar
Yeah, i was just goung to peel up a small corner at a time and drip 3M adhesive remover on it, then dental floss it off. Thats what i did on my bimmer and did the trick. Its also black
Old Feb 7, 2005 | 06:39 PM
I got hit in the side a few months ago and had the body shop do it during the repair.
Old Feb 7, 2005 | 06:45 PM
RACER's Avatar
A heat gun will cause the glue to melt and make it a lot easier to get off. If you don't have a heat gun, a blow dryer will work.
Old Feb 7, 2005 | 06:47 PM
Stratocaster's Avatar
Read this http://www.handa-accessories.com/S2000/s2kblkchrm.pdf. it covers the removal and reinstallation of that part. Just don't reinstall
Old Feb 7, 2005 | 06:49 PM
msm_s2k's Avatar
Same adhesive solvent used to remove front and rear H badges will work just as well on the S2000.
