lil help
Old Sep 23, 2012 | 08:42 PM
nissfam's Avatar
Default lil help
[attachment=27519hoto-24.JPG]
In the final stages of my build... I did the secondary air pump delete which freed up one of the vac lines under the fuel rail. I am left with this. What is the valve and what/where do you guys route and use it for? I am running a 6265 setup.
Old Sep 23, 2012 | 09:00 PM
nissfam's Avatar
ive looked at a vacuum diagram and it shows it as just a check valve and bulk vac hose...
Old Sep 24, 2012 | 05:58 AM
nissfam's Avatar
any ideas of what other guys are doing with this line after secondary air pump delete is fine.
Old Sep 24, 2012 | 11:02 AM
nissfam's Avatar
bah! bump for any suggestions.... should it be plugged? BOV still using the check valve?
Old Sep 24, 2012 | 01:52 PM
herecomesboost's Avatar
Remove all of the vac lines associated with the secondary air pump (to include the check valve in your hand in the pic)
Old Sep 24, 2012 | 02:13 PM
nissfam's Avatar
Just put a rubber plug over the end of the metal pipe?
Old Sep 24, 2012 | 03:37 PM
Remove the two metal lines that run laterally across the intake manifold. Use the nipple on the intake manifold as a vac/pressure source for your bov.
james0933
Aug 26, 2019 08:48 AM
akm446
Aug 29, 2018 09:08 PM
Margil
May 13, 2014 01:51 AM
miamirice
Jul 6, 2010 02:10 PM
WalkingDrunken
Feb 23, 2006 04:20 PM
