DESPERATE NEED OF HELP!
Old Apr 14, 2010 | 03:37 PM
silver696's Avatar
Default DESPERATE NEED OF HELP!
ok everyone, now im getting frantic/furious. im stranded away from my home, school and work with my 96k 2002 S on jackstands. i performed a simple slave cylinder replacement last night and am trying to bleed the system. ive been following the clutch bleed procedure and gone through the
open valve,
push pedal,
close valve,
pull pedal,
steps close to 50 or so times and nothing but air has been coming out of the valve. the fluid level in the resevoir has remained the same the entire time. i tried removing the slave and actually filling it with fluid before putting it back on to reduce the amount of air in the system and this did nothing but make it harder to reinstall but still nothing but air comes out. i really am getting desperate for help.
Old Apr 14, 2010 | 03:53 PM
rspenc's Avatar
I think you need to:
Push pedal
open valve
close valve
pull pedal
Repeat until no air comes out. Check reservoir every 3-4 cycles and fill as needed. This insures your not introducing air into the system.
Old Apr 14, 2010 | 04:05 PM
silver696's Avatar
ive been using xvipers procedure as posted here:
http://forums.s2kca.com/showthread.php?t=12154
i have used this procedure in the past but all we were doing was flushing/bleeding the system.
Old Apr 14, 2010 | 04:22 PM
spets's Avatar
just gravity bleed it..open the bleed valve and leave it open. Leave the cap off the reservoir. Fluid should come out.
If nothing is coming out, did you put the banjo fitting on in the correct order? bolt, washer, fluid hose, washer, slave cyinder.
Old Apr 14, 2010 | 05:27 PM
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
The clutch cannot be bled by pumping and opening.
UNBOLT the slave, leave line attached. Fill the res.
Pedal up, no one in the car.
Point the bleeder straight up, and open it. Gravity will push the air right out.
If it doesn't, something is wrong with the install.
Old Apr 15, 2010 | 04:40 PM
silver696's Avatar
i figured it out. im an idiot and too embarassed to even say what the problem was. i guess thats what i get for trying work on the car at midnight after school and work.
Old Apr 16, 2010 | 06:25 AM
AJ_72's Avatar
You should post what you did...you may save someone, like me, from repeating the same mistake! ;-)
Old Apr 16, 2010 | 06:28 PM
chino101's Avatar
Where you looking at the brake reservoir instead of the clutch reservoir?
tbpom1003
Dec 28, 2014 01:01 PM
Swiftoy
Aug 7, 2006 01:30 PM
WalkingDrunken
Feb 23, 2006 04:20 PM
terahertz
Aug 16, 2005 12:57 PM
2kturkey
Mar 30, 2001 04:14 PM
