When removing the air pump
When removing the air pump, not the engine
, does the valve on the intake manifold need to be blocked off or can you just leave the valve in place and it'll stay shut?
I always see people saying that they blocked it off but is that just so you can remove the valve and get a different look, and also lose that .1 pound.
, does the valve on the intake manifold need to be blocked off or can you just leave the valve in place and it'll stay shut?I always see people saying that they blocked it off but is that just so you can remove the valve and get a different look, and also lose that .1 pound.
I just went out and checked. I could not find any deffinitive evidence that any air comes out. I could not feel any air coming out of the valve at all even when reving it up a little. Is there someone with a a more clear cut answer to if air does come out of the valve.
I just took a look at the air pump and now I think that if you leave the solenoid on the car then you don't need a block off plate because it will stay shut since it has no function with the EMS. Is this correct?
jimtway1
Jul 1, 2010 10:00 AM
