In desprete need of help!
Ok so last night i droped my S with springs everything went smooth so when i get into my car i turn it on i get VSA ABS the triangle with the ! in it????? I disconnected the batt. to see if it would reset nothing. The car is an 07 lease so i really don't want to take it to honda WTF should i do i going crazy this is my brand new baby...........
WHAT SHOULD I DO???
WHAT SHOULD I DO???
You may have damaged a VSA sensor during installation. I can take a look at my service manual when I get home.
You could take it in as is or put the stock springs back on and then take it in. If you don't put the stock springs on and it turns out a sensor is damaged they may accuse you of damaging it during installation. On the other hand it may be obvious that you did so anyway.
It could be something completely different, this is just a guess.
I leased a car a while back and installed a ton of bolt-ons including a suspension. The dealer will definately make you pay for the fix. When you return the car, put it back to stock, and you'll be fine(Assuming you get the current problem fixed).
Originally Posted by SheDrivesIt,Aug 2 2007, 05:05 PM
You put a drop on a leased car?
don't ever lease a car unless its a write off for bussiness ...what a suckers bet pay ,pay ,pay and then walk away
buy the same model 2yrs old have the same payment to own it
....don't have the money to own it , don't bother drivin it
after i had a lot of work w/ the brakes and suspension on my s2 i had the ABS light on my display as well. i dont know if the 2007 has the same system as my 2000, but i know that the ABS light was only up on my car because the ECU and brakes had been disconnect and w/o power for so long it just needed to kind of reset. I drove the car for a week w/ the ABS light on and as the week progressed the light would be on all the time, then about 1/2 the time, and by a weeks end it was gone completely, never had a problem with ABS at all and that was 2 years ago. Whle the light was on, my ABS was still functioning too.
fixed it! it was the abs sensor! I lease it cause it is my work car!!!! I will put a bunch of bolt-ons and when it's time to turn it in i will put it all back to stock don't really see the big deal!!!! anyways thanks for the info....
oh and yes the dealer has no prob with me lowering the car or putting exhaust i get a write off with every part i put on....
s2kdan05ems
Jan 10, 2013 03:56 AM
I'm pretty sure that's not something allowed in the lease agreement.
