DId Compression Test and...
the results were
#1...250psi
#2...255psi
#3...255psi
#4...260psi
Seems PRETTY HIGH compare to what other ppl's test.(low 200s)
This is good thing right?
My car has 19000mile, never adjusted valve yet.
#1...250psi
#2...255psi
#3...255psi
#4...260psi
Just out of curiosity... what were the ambient temps when you did this? I've noticed that my numbers seem higher when it is cold out. Mid-summer (ambients in the 80-90 degree range) I had numbers in the 230-235 range. Today (ambient temps in the 50s), I had numbers in the 245-255 range.
Originally Posted by Amit' date='Feb 21 2005, 10:47 PM
If I wanted to test my engine condition, is compression test the best way to tell? Where can I get one done, and how expesive/complicated is it?
Any decent mechanic can do a compression test. It's not complicated at all. You pull the spark plugs, install the pressure gauge, turn the engine over through three or four compression cycles (most manufactures recommend WOT at this point too!) and read the gauge. I would hope that the S2000 wouldn't call for more than an hours shop time to do the job and any decent mechanic can probably do it a lot faster than that.
FWIW,
Drive Safe,
Steve R.
It was around 30F when I ran the test.
Cool outside air temp mean the air is more dense. That's can't hurt. The engine should also be at or near normal operating temps because that insures that everything is warmed up and expanded to the tolerances that Honda intended for the engine to run at.
Drive Safe,
Steve R.
Drive Safe,
Steve R.
Moddiction
Jun 20, 2008 08:53 AM
