Did Coolant Flush
Old Apr 17, 2006 | 06:37 PM
Squeezer's Avatar
Originally Posted by Race Miata,Apr 17 2006, 07:42 PM
I would disconnect the rubber hose to the reservoir and blow compress air into it with the rad cap shut instead.
On another note, a question to all, since I got my '00 used and have no way to know if the coolant is original, is it possible to tell from the color or whatever that whether the PO has replaced the coolant with Type II?
hrm i never thought of doing it that way.
honda type II is blue
you can use any silicate-free coolant in the s2000 though. I use a long life orange silicate-free coolant.
Old Apr 17, 2006 | 06:38 PM
Squeezer's Avatar
Originally Posted by XclusiveAutosports,Apr 17 2006, 07:57 PM
Let me ask you guys something, I also did a coolant flush and then I let the car idle to operating them and then shut the car off and opened up the bleeder valve to let off the air in the lines, but after I didn't feel that it did the job adequately I let the car idle up to operating temp with the rad cap off until the fans cycled on twice, but I didn't open up the bleeder valve, would this get rid of the air in the lines?
you are supposed to open up the bleeders when you add coolant. you don't want to open them when hot as the entire cooling system is pressurized. it would probably be like taking off the rad cap when the engine is hot which is a no no
Old Apr 18, 2006 | 07:38 AM
S2kracka's Avatar
It is blue now, it used to be green. There are no differences between the old and new TypeII other than color.
Old Apr 18, 2006 | 08:22 AM
Jasonoff's Avatar
Banned
I did the procedure correctly so it was just bad luck.
Everything is ok now. There was too much air in the system and it just took time to work its self out.
I've never had trouble flushing coolant before until I did one on this car. Same thing with the brakes, I can never get a good bleed using the pedal or a vacuum pump at the calliper.
krnmike
Dec 8, 2008 03:37 PM
CHUCKLIDDELL101
Mar 25, 2007 09:33 AM
kleecker
Mar 19, 2007 02:55 PM
7900S2k
Dec 23, 2002 06:33 AM
BBY2KS2K
Dec 22, 2002 11:32 PM
