Diff Fluid
Old May 31, 2005 | 10:22 PM
RsxFlyBy's Avatar
Default Diff Fluid
Hello,
Today I took my car to be serviced where my step-father works, it's a very nice Mercedes-Benz dealer here in Georgia (Atlanta Classic Cars). I figured even though my car is not a MB they must do good work. I figured I would take it there because I get a discount on the labor. I bought all the fluids myself and brought them there to be used. I had the following work done. Some of the work is a little premature on a car with 23,000 miles but i like to be up to date. This is already by second diff fluid change.
1. Tranny fluid change with Honda fluid
2. Clutch Bleed with ATE Super Blue (yes i know its overkill but hey it doesnt hurt)
3. Brake Bleed with ATE as well
4. Motor Oil change with Mobil 1 10w30 full synthetic
5. Diff fluid change.
my question comes to this. I brought the technicial a box of all the fluids i ordered, some were going to be extra for the next time, there were 2 quarts of Mobil 1 75w90 gear lube. everything i have read says that it only takes MAYBE one quart. somehow he managed to get about 1.75 quarts in my MY04 diff. i was wondering if this may seem a little unusual to anyone? just out of curiosity. thanks everyone!
-antonio
P.S. if this is unusual can any harm come from filling it too much? thanks
ALSO: they had a black SLR on which the dealership TURNED DOWN $1,000,000. they are looking for $1,500,000. TALK ABOUT SOME MARKUP! DAMN!
Old May 31, 2005 | 10:33 PM
Shadow_S2K's Avatar
Former Sponsor
Wow...that seems like an abnormal amount of diff fluid. I've changed mine twice and I've never used more then one quart of the Mobil 1, even have some left over. But...the more in the diff, the better it will protect. But dang...1.75 quarts is alot.
Old Jun 1, 2005 | 04:48 AM
BELGIUMPAUL's Avatar
pretty difficult to overfill it as the fill hole is also the level hole so the more you put in over the level the more that will piss out so to speak
my bet is that they used it on another vehicle
kind of you to supply the material !
Paul
Old Jun 1, 2005 | 07:41 AM
xviper's Avatar
[QUOTE=RsxFlyBy,May 31 2005, 11:22 PM] somehow he managed to get about 1.75 quarts in my MY04 diff.
Old Jun 1, 2005 | 08:48 AM
Wisconsin S2k's Avatar
how much MTF fluid did he use? If he used only about 1 quart, then he did exactly what xviper said he did. and he owes you a new tranny.
Old Jun 1, 2005 | 08:53 AM
Conedodger's Avatar
[QUOTE=xviper,Jun 1 2005, 11:41 AM]This is the exact amount that goes into the transmission.
Old Jun 1, 2005 | 09:15 AM
spesrf25's Avatar
God be with you.
Old Jun 1, 2005 | 09:26 AM
rworne's Avatar
Originally Posted by xviper,Jun 1 2005, 08:41 AM
This is the exact amount that goes into the transmission. Are you sure he put the GL-5 fluid into the diff? It only takes about 0.8 qt. What did he do with the MTF?
If you have the diff fluid in your tranny, be prepared for the tranny to start to whine. Then be ready to buy a new tranny.
If he put the MTF into the diff, then you might be able to get away with it as long as you haven't driven it much. Get that stuff right away and put the proper stuff in.
However, your tranny won't be so lucky as the GL-5 has already begun to eat away at the syncros.
You may have figured WRONG!
And for what it's worth, get samples of the oil when they drain it. You'll need it if there are any problems and you can check if they messed up by comparing the samples - the diff oil is thicker and stinks of sulphur.
Old Jun 1, 2005 | 11:06 AM
xviper's Avatar
It's a Benz dealer. They can afford it.
ps. I hope I'm wrong, too.
Old Jun 1, 2005 | 11:08 AM
xviper's Avatar
Originally Posted by Conedodger,Jun 1 2005, 09:53 AM
Hope xviper is wrong and you can find a good answer to this one.
Maybe the guy jacked the back of the car up in air 4 feet to get all that fluid into the diff.
