Diff Fluid
Old Jun 3, 2005 | 12:53 AM
  #31
Tony Yeung's Avatar
I did my diff fluid change today. I only bought one bottle of mobil 1 75w90 gear oil and after i drained the oil for 5 or so minutes, put the drain bolt back, pumped the bottle of fluid in the fill hole, no excess came out at all . Im worried but not sure if it will cause problems. Ill prolly get another quart and pump more into it till excess leaks out? What you guys think?
Old Jun 3, 2005 | 01:08 AM
  #32
RACER's Avatar
Originally Posted by Tony Yeung,Jun 3 2005, 01:53 AM
no excess came out at all ?
The diff on this car takes .8 quarts of gear oil. It wont puke over flow due to .2 quarts. If you put the entire bottle into the diff, your good to go, call it the day
Old Jun 3, 2005 | 04:38 AM
  #33
xviper's Avatar
Was the car level?
Old Jun 3, 2005 | 05:27 AM
  #34
stitos2k's Avatar
Has any considered yet that the tech probably used pumping device with its own tank? He probably just put both bottles in there and started pumping away.
My mechanic uses one which is why I know. You poor the fluid of choice in the tank, pump a handle to create pressure, and fluid goes through a tube to the tranny.
I'm betting he didn't know how much he'd need and just poored in what he thought would cover it.
(btw, yes my mechanic thoroughly cleans the tank and the hoses before each new fluid is poored in. He really hated me for the LE-607 haha)
Old Jun 3, 2005 | 06:37 AM
  #35
Tony Yeung's Avatar
i used a friends lift at his shop, the car was dead level. Im thinking i should put it back up and pump some more in just to be safe.
Old Jun 3, 2005 | 08:52 AM
  #36
littlerocket777's Avatar
I just did the diff fluid change in my garage and even though I squeezed some fluid to sort of flush it (there was so much gunk on the mag drain bolt, amazing, never seen anything like that) and spilled a bit and still had a bit in the bottle, when I lowered the car, some still came out. Quite a lot actually. So honestly, I am befuddled as to how some of you can put in that much and have nothing roll back out. And I raised just the back half of the car, drained, cleaned, refilled, lowered with the fill bolt off, let excess drain, reached in to tighten bolt, raised car, torqued, cleaned, dropped car.
Old Jun 3, 2005 | 01:35 PM
  #37
Billman250's Avatar
Active Streak: 30 Days
Active Streak: 120 Days
Top Answer: 1
Originally Posted by xviper,Jun 2 2005, 08:37 AM
With the car being level like this, it is hard to put all 2 qts of fluid into the tranny and definately impossible to put 1.75 qts of fluid into the rear diff. Fluid would be oozing out of the diff before he even finished the first bottle.
This is exactly my experience, with 00-05 difs...
Prolly done over 200 s2k dif changes...correct amount for the dif is slightly less than one quart. Don't think your slick by putting in more than recommended...you can blow seals and cook the dif.
Trans takes more than 1.5 qts, less than two.
sanjay
Apr 9, 2009 04:04 PM
Kaiser
Mar 1, 2006 08:24 AM
jojipoji
Nov 5, 2004 10:57 AM
TunedS2000
Aug 21, 2004 06:52 AM
S2WOOOW
Jun 13, 2002 04:31 PM
