Which diff oil
Old Nov 7, 2005 | 07:03 AM
R2S's Avatar
R2S
Default Which diff oil
I need to switch out my diff oil since i know it's never been changed (35 K).
I called Honda and they gave me the specs (since they don't have there own oil).
SO, I bought some Amsoil Sever Gear 75W90.
It's what Amsoil recommends and it for GL-5/hypoid gear applications.
Before I make a $3000 mistake and put this stuff in, anyone have any experience with it or any comments??
Thanks in advance!
Old Nov 7, 2005 | 10:13 AM
Gloffer's Avatar
Don't know anything about the Amsoil, you could do a search for other users. In general, Amsoil products are better than most if they're used in the correct application.
Personally, I think the "best" fluid for an S2000 differential is LE 607, especially in warm weather applications. http://marketplace.s2ki.com/s2ki/product.p...1&cat=24&page=1
A lot of drivers are using Mobil Synthetic 75W-90 Synthetic Gear Lubricant.
Do a search these types of questions have been asked and answered hundreds of times.
https://www.s2ki.com/forums/index.php?showtopic=195574
Old Nov 7, 2005 | 10:27 AM
S2KenC's Avatar
Just changed my diff fluid this weekend with Mobil 1 75w90. I've been running this fluid on both my 2002 and 2005 models. Knock on wood...no problems yet.
Old Nov 7, 2005 | 02:25 PM
R2S's Avatar
R2S
couple more questions....what exactly is the correct weight for the diff?? I believe the manual said SAE 90, but my dealership and many people here are using 75W90 or 80W90.
also, I recall with a search on s2ki.com that some people had diff failure with LE-607...just my imagination?
also, can I use diff oil with friction modifiers??...the amsoil uses them in the "Severe Gear"
thanks again!
Old Nov 7, 2005 | 07:46 PM
Emil St-Hilaire's Avatar
Active Streak: 30 Days
Been using Redline 75W90 gear oil for a while,and very satisfied.
Wanted to try the LE 607,but shipping from MARKETPLACE was too damn expensive!!!
Old Nov 8, 2005 | 01:02 AM
Trigun's Avatar
Has anyone tried Motul differential oil?
Old Nov 8, 2005 | 02:39 AM
CoralDoc's Avatar
I do not recall anyone ever reporting a lubrication-related differential failure when using LE 607 in an S2000. If anyone knows of a case, I'm sure that Lubrication Engineers would want to hear about it.
Friction modifiers are not necessary for our Torsen-type differential, but they will not hurt it either. They are needed by friction plate type designs like the Mazdaspeed unit in my Spec Miata and the limited slip diff in my wife's F250.
Old Nov 8, 2005 | 09:59 AM
Jay2000's Avatar
I have been using amsoil for years in my diff, no problems yet.
Old Nov 8, 2005 | 11:22 AM
R2S's Avatar
R2S
Jay2000,
Do you also use the "Severe Gear" formulation from Amsoil?
TIA!
Old Nov 8, 2005 | 07:39 PM
hackmac87's Avatar
LE607 nuff said
Mexs2k
Aug 18, 2016 05:05 PM
tntrac
Jul 14, 2010 12:54 PM
s2k demon
Jul 6, 2008 02:13 PM
rm7boy
Jan 16, 2006 06:30 PM
Chrisko
Aug 4, 2005 11:14 PM
