Diff oil weight recommendation? 2018
Old Sep 25, 2018 | 12:51 PM
  #131
rrounds's Avatar
Originally Posted by SpitfireS
....Motul is most likely going to answer in this way:
"Eventhough you can mix the oils and the mixture will flow (meaning it will not form weird chemical reactions and produce semisolid blobs of goo) we advise to use the product we have engineered as is to use the properties to the fullest"
Correct me if I'm wrong.
I know Red Line says to mix away, you can use any of their GL5 gear oil in any % you want to use.
They even say to mix 75/140ns with mt 90 or 75/90 to bring up the vis. on their web site
75W140NS GL-5 GEAR OIL
  • Option for noisy transmissions when mixed with 75W90NS or MT-90 to bring viscosity level up
  • Also used in clutch-type limited slip differentials in racing for maximum lock up-some users add Limited Slip Friction Modifier in small doses to customize slippag
    https://www.redlineoil.com/75w140-ns-gl-5-gear-oil
    I got a E mail from Red Line 6 or 7 years ago that said I could mix their MTL, MT85 or MT90 to get the right viscosity for my transmission and thats what I do for my S.
ROD
Old Sep 25, 2018 | 07:43 PM
  #132
Vitt's Avatar
ROD
I also called Redline several years ago to ask what I should use because I had too much MT90 on hand and a couple of MTL. The guy I spoke with told me that while MT90 was too thick to be used alone in the Sk2's tranny, I could use 1 QT of MTL and top it off with MT90.
Old Sep 25, 2018 | 11:27 PM
  #133
RolanTHUNDER's Avatar
I'm just gonna leave this here...
Old Sep 26, 2018 | 12:35 AM
  #134
Mr.Matchbox's Avatar
I just have send a mail to Motul.
Old Sep 26, 2018 | 08:57 AM
  #135
SpitfireS's Avatar
Originally Posted by RolanTHUNDER
P.S. I'm curious, do you still love your AD08R's or found something else as great/better?
Oh yes, they are the best tire I've used so far.
The front/rear ratio of the AD08R's is different than the original S-02's (the AD08R fronts are percentage-of-the rear wise substantially wider than the front S-02's) so I did change the OEM front sway bar for a Whiteline (= stiffer) to compensate.
And as far as I'm concerned that worked, in combination with the Koni Yellows on pretty much OEM ride hight I think the car handles better than original.
The alignment is UK-spec but without the rear toe-in listed in that spec, that's way to much as 'we' concluded in a thread in UTH a while ago (it must be still out there)
And replacing all those rusted solid bushings & pins helped too: no hidden pre load and butter smooth alignment, even after 10 years.
Are we going to turn this into a suspension thread now?
Haha!
Old Sep 26, 2018 | 09:06 AM
  #136
SpitfireS's Avatar
They even say to mix 75/140ns with mt 90 or 75/90 to bring up the vis. on their web siteROD
They know their product better than any.
If you KNOW your oils share ALL the additives and ONLY the base oils are different, then sure.
Do you have any info on that, MSDS's?
Going by what Mr.matchbox posted where was mentioned the one oil has this sulphur smell (and the other one does not I assumed, later showed by MSDS) they for sure have a different additive package.
Mixing in that case dilutes additives and that's bad... mmmkay.
Last edited by SpitfireS; Sep 26, 2018 at 09:09 AM. Reason: added mmmkay because we're all still having fun.
Old Sep 26, 2018 | 04:37 PM
  #137
simons's Avatar
Originally Posted by Opie Oils
I suspect you are not far wrong, and they will mix without issue and work fine. But still cant quite work out why the need to do this, the diff will work just fine on 75w-90 and will also work fine of 75w-140 as some feel the need to use.
Motul should reply to you no problem, but if you do not get the info you are looking for let me know as I can forward your questions on to my technical contacts at Motul.
Cheers,
Guy
whats your opinion on regular (i dont know the correct word) vs sythetic oil for the diff?
Old Sep 26, 2018 | 04:40 PM
  #138
simons's Avatar
omg did YOU actually read post #32?
Like... the first 3 sentences?
It was posted... you know... like... 79 posts ago?
whats your point man? What does your msg#32 have to do with the email from Torsen? And what is "atf" fluid?
whats your point?? Just be clear. Thanks
Old Sep 26, 2018 | 10:09 PM
  #139
Haha!
No we're not and just to avoid other posters getting annoyed we'll stop here lol.
Glad to hear about the AD08R's. Fantastic (140...?) TW tire! Definitely on a higher level of grip/performance than the OG S-02's and even my Toyo Proxes T1S. I may consider running a set of 08's for the track or at least the rear end since I have a spare set of rims.
I too run Koni Yellows but with Tein S Tech springs. Great combo and she definitely handles better than stock with more lateral grip/stability and higher g's during hard cornering. That being said originally she handled damn good.
Back to oil
Old Sep 26, 2018 | 10:14 PM
  #140
The word is "mineral". Mineral oil generally doesn't flow as well/fast as synthetic and doesn't have the same additive packages as synth oil however I think that applies more to motor oil than diff/gear oil although, I could be wrong. Actually why wouldn't it apply to diff/gear oil now that I think of it...
In general its best to run synth all round. That being said I picked up that bottle of Liqui Moly I posted here and it's GL5 hypoid, LS oil all that jazz but is mineral hence the lower price tag. It's been sitting around unopened for months. Now I'm wondering whether I should throw it away and just splash out on the synth variant...
Synth oil comes from a higher refined base oil as well. Can go longer than mineral oil without breaking down as early.
