DIFFERENTIAL
Old Jan 16, 2009 | 06:58 PM
s2kbtos's Avatar
Default DIFFERENTIAL
hello;
i'm planning on getting a new diffrential, because my current one has problems, i have a ap1 2002 with 4.56s.
will a 2005 ap2 differential fit my car, i'm planning on changing the gear over to the new one.
Old Jan 17, 2009 | 05:04 AM
negcamber's Avatar
What is wrong with your old diff? Asking since moving the old gears to the new diff may bring the problem with it.
Yes and ap2 diff will fit. You do have to change the flange to the tranny though.
Old Jan 17, 2009 | 07:40 AM
ans2k's Avatar
^^^yep!
Old Jan 17, 2009 | 08:18 AM
s2k aok's Avatar
i have 4.77s and there is no problem and no whine. the 4.56s are going to be the loudest of all to my knowledge, is that the extent of the problem? moving your 4.56s to the ap2 housing might be a tad stronger though but i'd just get a comptech reinforced differential, not as strong as a puddy differential but it's not too costly...
Old Jan 17, 2009 | 04:19 PM
s2kbtos's Avatar
my differential is making a whining sound and i don't know if its the shiminig or the lsd, also there is a click sounding when i turn right.
so the ap2 differential just bolts on to the ap1 driveshaft and all bolts fit with no problems?
Old Jan 17, 2009 | 06:18 PM
negcamber's Avatar
You know that loud whine is normal for 99% the 4.56 gears out there.
Old Jan 17, 2009 | 07:22 PM
Stratocaster's Avatar
Actally that is a bad general statement. It was more true of a bad installation that anything else. The 4.57 made more noise then the 4.56 gears did.
The installer makes all the differance in the world when it comes to gear installation. I have heard 4.44 that we louder than a 4.57 gear set. I have also heard a 4.56 that could not be heard.
Old Jan 17, 2009 | 08:24 PM
s2kbtos's Avatar
after the installation of the gears , few weeks later i did a couple of burn outs and the whining sound started so i took it to the mechanic that installed it and he said that the bearing inside were like not shiny, but it was not chewed up.
he changed the bearings and the noise was still there, and a year later i have launched it several times and the same noise still there, like i stated before there is a clicking noise when i turn right, i don't know if its because the lsd is locked.
Old Jan 17, 2009 | 08:44 PM
negcamber's Avatar
My 4.56s were done by HT's installer...they are quite loud. Not as loud as Highlander's 4.57 car (my pumpkin was installed in his garage). I've ridden in Puddy's car...can't recall if he was running 4.44s or 4.56s but they weren't silent either, but quieter than mine. But all the 4.56 gear owners I've talked with have complained of whine being louder than expected after the redesign. But I'm sure there's the 1% out there that are nice and quiet.
Old Jan 17, 2009 | 08:57 PM
You know, that is not something we had ever really heard reports of. I find it strange that a 4.56 is louder than a 4.57. The tooth count is so differant (4.56 is about the same as stock ring/pinion) . It really makes no sence at all.
But with the Puddy gears (457) being quite and yours (456) louder, that shows how well he isntalls a set of gears.
I know that all of the gear sets we isntalled and shipped, I don't remember any reports. Surely not like the 4.57 reports.
RedSunS2K
Mar 20, 2014 06:54 PM
BB02s2k
May 22, 2013 02:22 PM
ZachRupple
Apr 20, 2011 12:53 PM
Nhan
Apr 3, 2007 08:51 AM
S2KHardTop
Jul 20, 2006 03:36 PM
