Differential Failure
Originally posted by gernby
If that is the only difference, why wouldn't Comptech sell the straps by themselves?
Thay machine the stock caps down to give a smoother surface for the reinforcement to seat against.
I ask this as a follow up.. Why can't you just take the OEM caps and rework them? I meed this would same on shipping, etc..
Becasue the bore of the housing is like that of a motor. Both the saddles and caps are bored when the unit is together. This means if the caps were seperated from the housing they were bored with, they would not fit another housing properly.
If you jack the rear of the car up, put the parking brake on with the car in neutral, then try turning the driveshaft hard in each direction, you might be able to see a half shaft moves around or makes a noise.
thanks all
Ashton23
Oct 11, 2024 07:14 PM
