Differential Fluid
Originally Posted by SuperSaiyan
Finally going to have time to do some service changes to my car. I was planning to do a full fluid flush to my car. I've looked up everywhere but I cant find the OEM honda s2000 differential fluids. I'm going to use the OEM Honda MTF for the transmission but cant find anything about the differential. I was also going towards the Amsoil but dont know what grade to get 75w90 or 75w110. Or should i go with mobil 1. I live in florida if that helps.
The factory put straight 90w in the differential when new. The nearest to factory spec is LE 1605 or a 75/110
For added protection and better performance from the LSD use a 75/140 There is no disadvantage to using the 75/140 at all
Amsoil, Mobil1, LE-1605, and Motul are some of the best on the market.
If any of you run a aftermarket clutch type LSD in the rear use the Motul 75/140 this oil is by far the very best I have used for clutch type LSD units
30k is the perfect mileage to do both under normal driving.
Trans fluid and dif fluid are not affected by time (unless its extended years) so doing them seasonally is a waste of time and money. Mileage is key.
Diff fluid is 90W single grade.
Honda doesn't sell this anymore, just like pretty much every one else. It's all multigrade these days.
I found a agricultural vehicle / lorry garage that still uses 90w for some weird machines. They sold me 2 L for 5 bucks or so. That's your best shot I think
You should be able to feel or hear when the transmission fluid needs to be changed. Especially in my RSX-S, the transmission gets noticeably notchier, and may grind into 3rd gear after several thousand miles. Changing fluid fixes it. I have heard that the long molecules in the lubricant can be cut by the gears (shear forces) and lose some of their lubrication properties.
The S2000 is a great, and valuable, car. Protect your investment. At least once per year. If you race, the higher temperatures also break down fluids, so racers typically change fluids after every race -- including brake fluid.
Don't neglect your hydraulic fluids and coolant.
