Differential Fluid Change
Old Jan 3, 2006 | 11:53 AM
CIVICTOS2000's Avatar
Nice Write up, I think I'll do this Next Week End...Thanks....
D.
Old Jan 3, 2006 | 01:34 PM
jasonw's Avatar
Originally Posted by vtec9,Jan 2 2006, 12:09 PM
the spec on both plugs is 33 lb-ft, but as mentioned in the original FAQ, you'll probably have a difficult time fitting your torque wrench and socket between the diff and the beam you see in the pics to remove/replace the fill plug. Because of this, I just use a regular wrench, and tighten the plug with the same force as I did the drain plug. This is not a critical bolt, so better to under tighten, then if it leaks, give it a bit more.
As an aside, there are adapters I have seen that should let you torque the fill bolt. They are like a 2" extension that snap onto the wrench. You do have to manually recalculate the torque because of the change in overall length though.
I just use a regular wrench(which was not easy to find in this unusual size BTW).
Old Jan 3, 2006 | 01:42 PM
ayS's Avatar
ayS
i need to get me a fluid pump.
Old Jan 3, 2006 | 01:47 PM
jasonw's Avatar
This one is supposed to be good:
http://www.amazon.com/gp/product/B0000AXBH...glance&n=228013
Old Jan 6, 2006 | 03:36 PM
move_right's Avatar
I didn't see this on FAQ's yet
Old Jan 6, 2006 | 05:21 PM
Hockey's Avatar
Something wrong with XViper's version?????
DIY Diff Fluid Change
Old Jan 6, 2006 | 07:46 PM
B.C.'s Avatar
LE 607 is thick. HEAT it up before you pump.
Everything else looks great.
BC
Old Jan 7, 2006 | 12:18 AM
steven975's Avatar
the sizes of the bolts would be a good thing to add as they are rarely used sizes and most here will need to purchase them.
Old Jan 7, 2006 | 08:25 AM
SIIK2NR's Avatar
The bolts you re-use....it's the washers you replace..
Old Jan 7, 2006 | 11:09 AM
move_right's Avatar
I saw Xviper's and I personally think this one is better. I have nothing against Xviper. SIIk's has great photos and part numbers, what is not to like? If something better comes along do you ignore it because you already have one in place? Look, the mods can do what they want and to remind you a mod was the first person who suggested it is moved there. I hope that answered your question.
