Differential Fluid Change
Old Jul 2, 2008 | 09:09 PM
Millenion LTD's Avatar
Default Differential Fluid Change
Hi, I followed these instructions...
https://www.s2ki.com/forums/index.php?showtopic=348700
However, when I was filling the diff fluid back in, when I pumped in 85% of a quart, it started leaking fluid back out already. What did I do wrong?
Old Jul 2, 2008 | 09:40 PM
AusS2000's Avatar
Hmmm, not sure exactly how much a quart is but believe it's close to a litre (what we use in the modern world). 85% would be about right then.
Old Jul 2, 2008 | 09:42 PM
AusS2000's Avatar
Ok, it's about 800ml.
So long as you drained the diff properly (warmed it up by driving a bit, jacked the car up so the drain was low) and made sure the fill point was high you should be ok.
Old Jul 2, 2008 | 11:46 PM
okay, well I drove it to a shop lift and everything was leveled from there. one of my buddies just told me i needed 2 bottles for some reason, he said i was going to use about 1.5 quarts.
thanks alot!
Old Jul 3, 2008 | 02:43 AM
INDYMAC's Avatar
I believe the diff holds 0.82 quarts of fluid. Sounds like you did it just right!
Old Jul 3, 2008 | 04:46 AM
ian05s2k's Avatar
did the same thing last weekend, you are fine.
-Ian
Old Jul 3, 2008 | 04:55 AM
s2VTeK's Avatar
1.5 quarts is for the transmission fluid
Old Jul 3, 2008 | 09:02 AM
innovation's Avatar
transmission is a lil more than that its like 1.8
the diff is .8 quarts.
Old Jul 3, 2008 | 11:36 AM
AP_ONE's Avatar
did mine 2 weeks ago, started to come out just a tad b4 the 800mm.
your good!
RedCelica
Aug 27, 2016 02:48 PM
SilverDC2 AP1
Oct 2, 2006 03:21 PM
spectacle
Jun 16, 2006 12:30 PM
jojipoji
Nov 5, 2004 10:57 AM
