differential question
Pleaser refer to this post guys: Thump noise when I put it into 1st gear. https://www.s2ki.com/forums/index.php?showt...0&#entry4068668
Any non-oem parst in the driveline / suspension?
Any work done on the diff (swap?)
Check your diff mounts.
If it sounds like the clunk you get when going (without waiting) to 1st from neutral at idle.. I guess your "noise" IS normal.
shakes Posted on Apr 1 2007, 04:39 PM
You mean : the driveshaft turns and the wheels don't?
How much does it turn?
Any work done ever on the diff?
(last time this gets asked....
when your letting out the clutch with no gas(very quickly) the driveshaft turns quick creating this noise.
