differential removal
Old 03-09-2009, 12:30 PM
s2k aok's Avatar
i good sized breaker bar smacked with a mallet does the job that an impact wrench would do and it is substantially cheaper.
regarding bolts/nuts, from what i can recall the four going from bottom are easily accessible. the harder ones are the nuts on the four studs coming out the aft end of the differential, i ended up ripping the studs out with seized nuts that i had to purchase at honda. of course there are the halfshaft nuts/bolts and should not have too much torque on them 'cause of their size. the lower ball joints need to be popped off (the castle nuts), and the prop shaft allen head screws.
i'm sure there must be install guides kicking around here or s2kca or something...
Old 03-09-2009, 12:31 PM
s2k aok's Avatar
a side note, you're using six-point sockets/wrenches not 12-point ones right?
Old 03-09-2009, 02:09 PM
SgtB's Avatar
I don't pop the ball joints. Pull the axle bolts, and the prop shaft bolts. Remove the rear diff mounts and then the four bolts that hold the diff to the front mounts. Once you do that you can wiggle the diff side to side and pull the axles out with a prybar..gently. I can swap it in about an hour with a jack and a few sockets.
Old 03-09-2009, 03:25 PM
Former Sponsor
Moddiction's Avatar
Was really easy to swing them out of the way with using a ball joint poper. Comes right out and the axles can swing out of the way. The diff driveshaft allen head bolts were the biggest pain. Had to saw 2 of them out.
Old 03-09-2009, 07:40 PM
s2kbtos's Avatar
guys i figured out how to take it out and now it has been shipped to puddymod for a nice stage 2 rebuild.
i will try to d a write up with pics , since the other DIY don't have one, and i also found the perfect tool to do the bracket bolts.
Old 03-10-2009, 02:40 AM
ndk4's Avatar
I remember doing this on my own for the first time about a year ago due to crapped out 4.57. what a pain. something i wish i never have to go through again. I got mine rebuilt from puddymod as well. good luck!
Old 03-10-2009, 01:10 PM
s2k aok's Avatar
i had to saw all six.
chubbys2k
02-22-2016 07:11 PM
13darkknight
09-19-2010 06:39 AM
duff0000
05-05-2007 04:02 PM
kenstyle
09-24-2006 03:39 PM
Quick Reply: differential removal
