Difficutly engaging 1st gear and Reverse
Old Oct 20, 2011 | 11:35 AM
craig2teg's Avatar
Default Difficutly engaging 1st gear and Reverse
Just about a week or so ago I changed my trans fluid using (GM synchromesh) followed the DIY to a "T" and was fairly easy. A few days ago I started to notice that it was difficult to engage 1st gear while at idle and it's difficult/almost impossible to engage reverse. I'm gonna switch the fluid again tomorrow to Honda MTF, I was wondering if anyone had any input or ideas to what the issue may be. All other gears are fine while driving and each gear pulls normally, the only issue is engaging 1st gear at idle and reverse.
Old Oct 20, 2011 | 11:39 AM
MaxV_'s Avatar
The same exact thing happened to me. Check the Clutch Reservoir. Mine was completely drained. If not then its probably the Master Cylinder
Old Oct 20, 2011 | 12:14 PM
D1sclaimer's Avatar
This is most likely the issue. It is in the engine bay against the firewall on the driver side if your car is left hand drive.
Old Oct 20, 2011 | 02:21 PM
craig2teg's Avatar
That was the issue guys the CMC reservoir was low...I feel like such a dumb#@$ . Thanks guys!
Old Oct 21, 2011 | 07:29 AM
TougeS2k's Avatar
I have trouble getting into first still when cold, changed master cylinder fluid and everything, no leak... *shrug*
b_ron
Nov 1, 2018 03:50 AM
SJean
Jun 27, 2012 05:06 PM
arab
May 6, 2009 02:05 AM
hyune_83
Oct 15, 2008 04:24 PM
Turtle636
Mar 12, 2007 01:48 PM
