Which Direction Does Oil Flow Through the Filter (ADVICE Needed!)
Old Jan 31, 2004 | 04:44 PM
cbender's Avatar
When installing my new CM cannister oil filter (thanks, DavePK, for the suggestion) and C&R radiator with built-in oil cooler, I used the same routing as had been used for the oil filter relocation kit that came with my turbo kit.
But I'd still feel more comfortable if I knew, for certain, that I'm running the oil in the right direction (from the block, through the filter, then through the oil cooler, then back to the block).
I'm concered for two reasons: first, the oil should be filtered before flowing through the oil cooler (thanks, UL, for the advice). Second, the CM filter is uni-directional.
So, does anyone know whether the stock oil filter works by sucking oil from the outside of the cannister through the center hole or vice-versa?
I've tried finding an oil filter relocation kit installation manual but nobody's got one online.
Thanks,
CB
_________________
C. Bender
2001 Silver/Black
AEM EMS, Fuel Pressure Regulator, and Wideband O2 Sensor; RC Engineering 550 Injectors; Turbonetics TO4B 60:1 Ball Bearing Turbo; Tial 46mm Wastegate and 50mm Blowoff Valve; GReddy EGT and Boost Warning Gauges; Auto Meter Oil Temperature Sensor; Holly 250 Forced Induction Fuel Pump; CM 6
Old Jan 31, 2004 | 05:13 PM
Road Rage's Avatar
I have never seen a spinon oil filter where it did not function from the outside IN.
If the S2000 is the exception, someone please let this man know.
Old Jan 31, 2004 | 08:37 PM
dhayner's Avatar
Pleated filter elements are stable with higher external pressure, but subject to buckling with higher internal pressure. Hence, they are set up so oil flows from outside to inside.
Old Feb 1, 2004 | 09:55 AM
cbender's Avatar
This is good news. Thank you both. That's how the oil filter kit was installed by Speedcraft, and it was under the belief that the oil filter relocation kit was initially installed correctly that we plumbed the new CM oil filter and C&R radiator. So, it that was done correctly then the new system is plumbed correctly, and I thank you both for the reassurance.
All the best,
CB
Old Feb 1, 2004 | 02:22 PM
Road Rage's Avatar
U are welcome, and you are smart to make sure of this, as the filter media would likely have fractured if reversed.
Old Feb 1, 2004 | 05:57 PM
cbender's Avatar
I tend to fuss about this sort of thing anyway, so it's really good to know that I've got it plumbed correctly and have nothing to worry about. I appreciate the help.
All the best,
CB
duhelo
Apr 28, 2016 05:33 AM
Tampa s2000
Dec 18, 2015 03:54 AM
skool u
Mar 16, 2009 01:16 PM
yellafeva
May 13, 2004 01:46 AM
