Disassemble Head
Old Mar 19, 2013 | 12:18 AM
Beho88's Avatar
Default Disassemble Head
How do I remove the tubes for the spark plugs on the head? My head is bad from a dropped valve so I'm trying to disassemble everything to recycle it for $$. Tried to twist and wiggle the tubes out but no luck!! Any help is greatly appreciated. Thank you!
Old Mar 19, 2013 | 03:22 AM
MM3Kwolik's Avatar
They are cemented and/or pressed in if I remember correctly. On previous Honda heads I've just used a cutting wheel to cut them off as close as I can for recycling. The only other thing that I can see working would be a high temp torch to heat up the head (expand the metal) and maybe they'll pull out then.
stand_firm
Oct 10, 2016 10:50 AM
gearshifter
Socal Swap Meet
Apr 13, 2009 09:48 PM
DVSwetwilly
Dec 31, 2004 03:12 PM
