Disassembling bottom end
Old Apr 17, 2006 | 01:37 AM
AusS2000's Avatar
Default Disassembling bottom end
I have a short block I'm disassembling. I'm down to the block, cradle and crank.
I've removed all the bolts around the outside of the cradle and the 10 crank bolts so I expect there is nothing but sealant and friction holding the cradle in place and the crank in. But my gentle efforts so far (with a rubber mallet and screwdriver) have failed to dislodge it.
Are there any hidden bolts I don't know about? Anything else holding it? Any technique? Or do I need to make a spreader tool?
Old Apr 17, 2006 | 04:00 AM
Slows2k's Avatar
10 maincap bolts, and 15 bolts around the girdle's perimeter. The oil pump and oil pump chain need to removed as well. (should be done to get to the maincap bolts)
There are a few places to put a large screwdriver between the girdle and the block, you just need a good amount of leverage.
Old Apr 17, 2006 | 04:13 AM
chris_barry's Avatar
Have half a box of Weetbix for breakfast and try again.
Chris.
Old Apr 17, 2006 | 04:33 AM
Slows2k's Avatar
Some beers may help out too.
Old Apr 17, 2006 | 03:03 PM
AusS2000's Avatar
Right, so beers, bran and brutality. Sounds like my kind of picnic.
Old Apr 19, 2006 | 06:07 AM
AusS2000's Avatar
Had some Sultana Bran and a couple of News then took a crow bar to it. Popped apart with a fair amount of leverage. Almost soiled myself after all that roughage.
Cheers!
Old Apr 19, 2006 | 06:25 AM
Wisconsin S2k's Avatar
TeslaChicken
Sep 11, 2015 04:55 PM
taylorsmith831
Aug 9, 2015 04:07 PM
_brandon
Mar 30, 2014 11:26 AM
shift9k
Mar 7, 2012 01:22 PM
dievoche
Jul 18, 2010 06:09 AM
