Disconnecting sway bars to adjust suspension?
I noticed on a couple threads that some recommend you loosen or disconnect the sway bars when getting the car corner weighed.
I have not gotten my car weighed, but I had a hard time setting the same ride height around my car. Everytime I adjusted one side the other would drop or raise accordingly both in the front and rear. Could this be the function of the sway bar being attached?
I had a weird incident recently, which also leads me to believe this. My rear suspension, after being adjusted a bunch of times to make it match, always had the driver side about 1/4 of an inch higher. I hit a massive dip the other day in the road, causing I the rear to hit the bump stops with a fierce bump. Well right after that, now both sides on the rear sit even and perfect. Could this have been the sway bar loosening or something back there?
turtlepower
Jun 30, 2018 11:15 PM
