DIY exhaust?
Old Jan 24, 2005 | 01:35 PM
kush only's Avatar
Default DIY exhaust?
hey guys, i tried the search and after the 8th page i gave up. can anyone link me to the DIY exhaust installation page if there is one? i plan on installing a single 2 piece exhaust tonight. thanks,
Old Jan 24, 2005 | 01:41 PM
AusS2000's Avatar
I'm not sure it is complex enough to require explanation.
Jack car up
Remove cross bar
Unbolt exhaust from cat
Slide off hangers
Discard
Fit new single exhaust
Reattach cross bar
Unjack car
Insert ear plugs
Annoy neighbours
Old Jan 24, 2005 | 01:50 PM
beanolo's Avatar
yea its a very easy bolt on... once you get under there you'll notice its pretty self explanatory
only PITA part.. is taking the hooks off the black rubber pieces... but i jus jabbed a screwdriver in there to pull em off
Old Jan 24, 2005 | 01:54 PM
AusS2000's Avatar
Bit of spray on silicon lubricant or similar helps.
Old Jan 24, 2005 | 02:02 PM
Hockey's Avatar
Here is one.......
Removing OEM Exhaust
-Hockey
p.s. Get yourself some "Liquid Wrench" or similar and spray the bolts on the flange. They can be a bugger to get off.
Old Jan 24, 2005 | 07:16 PM
sanee515's Avatar
use WD40 on the bolts and the hangers. it helps A LOT!!!!!!!!!!!!!!!
Old Jan 25, 2005 | 02:13 PM
r_duff's Avatar
Tools u need. Long socket 12mm. 10 mm. 14 mm. jack and jackstands.
Old Jan 25, 2005 | 11:27 PM
Rusler Firbrand's Avatar
soak it in wd40 the day before, it will help alot.
also, if u decided to drive aroudn with no exhaust, i think it sounds crazy.
when you hit 9k its over.
zzkamikazezz
Dec 17, 2011 02:15 AM
Ahwa2k
May 25, 2011 12:18 PM
JamieT
Jul 29, 2010 12:28 PM
David-D
Apr 27, 2007 09:32 PM
mrkim019
Dec 26, 2001 06:01 PM
