DIY Fuel pump
Old Feb 25, 2006 | 06:51 AM
GDM S2K's Avatar
Default DIY Fuel pump
Anyone do a FYI on our fuel pump or can give some advise for changing it?
Old Feb 25, 2006 | 06:54 AM
xviper's Avatar
Look at this Vortech manual for the supercharger kit. It shows how to change out the fuel pump:
http://www.vortechsuperchargers.com/...s/4hs218im.pdf
Old Mar 4, 2006 | 02:27 PM
XclusiveAutosports's Avatar
I just did my fuel pump the other day. From what I had read on the forum I thought that the install was going to be a nightmare, but it turned out to be quite easy and straight forward. I also used the instructions that Xviper just linked to you to help me out. Basically, first you need to take the rear deck trim out, it consists of the two plastic pieces that the soft top folds down onto. You will just need to pop out about eight or so clips and drop the piece down through the trunk. Next, you will need to take out the lining in your trunk and the spare tire for some space. You can then remove the 3 screws that hold the top of the fuel pump and disconnect the electric harness that goes to the top of the pump. Then you can disconnect the two fuel lines that are connected to the pump and remove the eight or so bolts that hold the fuel pump down. You can then pull the pump assembly out and remove the actual pump. You are simply swapping it out, and you will need to remove another electric clip that is attatched to the stock pump and when you replace it with the walbro unit, or whatever you are using, you will have to cut the rubber hose about a 1/4" or so to make it fit snugly. Then just drop it back in and bolt it up. The install only took about 25 mins once I got all of the plastic out, I was pretty shocked. Have fun with the install.
Old May 18, 2006 | 03:54 PM
gotswap's Avatar
Much thanks to xviper again for the valuable link. Helped immensly!!!!
Old May 18, 2006 | 04:02 PM
xviper's Avatar
2.5 month old thread and still useful.
Old May 18, 2006 | 04:14 PM
GDM S2K's Avatar
Putting 2 in was easy too
Old May 23, 2006 | 07:30 AM
RobbieS2000's Avatar
Thanks for the instructions Install was a breeze!
Old Mar 7, 2008 | 08:11 AM
s800's Avatar
Link is broken now, but you can get there here:
http://www.vortechsuperchargers.com/suppor...-%20Honda/Acura
Old Mar 25, 2008 | 05:34 PM
s800's Avatar
Also, I should say that you can get the rear tray fasteners out from the trunk, by squeezing and pushing up. This was easier for me than from above, since the rear ones aren't the neato push and release fasteners.
jco2301
Jan 28, 2014 04:28 PM
s2konroids
Apr 24, 2010 11:35 PM
supwitu
Jul 12, 2007 07:45 PM
Dolemike
Jul 6, 2006 11:48 AM
D-S2K
Nov 11, 2005 02:51 PM
