DIY Spark Plug replacement(pics)
Old May 13, 2009 | 11:43 AM
  #21
Skatethesea's Avatar
im pretty sure that the tq spec is from 18-19ft lbs. But you might be right since i dont read service announcements. I am too lazy
Old May 13, 2009 | 04:16 PM
  #22
negcamber's Avatar
Hey...thanks for putting this together. We lost our DIY when some of our previous members left the forum.
If you don't mind, I'll make a few changes and post it in the sticky.
Old May 13, 2009 | 05:12 PM
  #23
yea man, do what you need to it. this is the first car i have ever even changed my own oil on so every sticky helps for people like me
Old May 13, 2009 | 08:13 PM
  #24
golfreak12's Avatar
Originally Posted by The Gent,Apr 1 2009, 12:15 PM
spark plug part number (Honda/NGK): 30520-PCX-007
If someone is wondering.
Why is it that I put that part # in google and all I get is Ignition Coil.
Old May 14, 2009 | 09:40 AM
  #25
Turbolag's Avatar
Originally Posted by CKit,May 13 2009, 10:22 AM
If you look at the pictures, he had Loctite BRAND anti-seize. Not Loctite RED or BLUE.
Weren't the torque specs amended to 21ft*lbs after people had problems with spark plugs backing out of the head and destroying coils?
Yep you are correct. I should have stated not to use any kind of thread locker. Loctite or any brand. Sometimes the name Loctite gets associated with only the threadlockers, not just a brand name.
Old May 22, 2009 | 08:14 AM
  #26
IMP's Avatar
IMP
The torque spec is 18ft/ibs. So wait for the pop and then your done with that.
I know my torque wrench works. I've tried 1 other that works also. However, I just put in new plugs, and being an aluminum head, I don't want to put too much pressure... but my wrench just doesn't want to 'pop' when doing the plugs, but it feels like I've put more than 18ft/lbs... but they just keep turning.
I'm just super worried about over-torquing them, or that the previous owner (or their mechanic) may have already done so on a previous set of plugs....
Thoughts? Should I just get one of the cheapie 'needle on dial' type torque wrenches?
--kC
Old May 28, 2009 | 11:01 AM
  #27
S2K000's Avatar
Question, if I need replacement coil packs, can I only get them through Honda?
Old May 28, 2009 | 11:53 AM
  #28
JP Money's Avatar
^No. I have seen them used (in great condition) in the for sale section. I picked mine up locally from a shop (again in great but used condition). Check in your local forum, you might be surprised what people have lying around.
Old Jun 9, 2009 | 03:13 PM
  #29
FromaDB2toanAP1's Avatar
When should spark plugs be changed? 45K miles? 60K?
Old Jun 9, 2009 | 04:47 PM
  #30
Nickamsweet's Avatar
the allen key is 5mm I think... not sure about the plugs, depends on how long you want to use them i suppose... I'm doing them every 30k or so...
